luvmyfamily
- Joined
- Jan 29, 2012
- Messages
- 796
- Reaction score
- 70
- Location
- Shepherdsville, KY
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #16
I hope you don't mind, your tag says 'OK' to edit your photos:
I dont know how accurate this is since I wasn't there, but this is why I suggest using a grey card (or white card). If your camera doesn't support custom WB by shooting a card, what you can do is take one photo with your reference card large in the frame under the light you'll be shooting. Then shoot as you normally would. Then when you get back to the computer, you open your photo with reference white/grey card and remove the color cast in PS (or whatever PP tool you use). You can usually save this adjustment and apply to all other photos in the shoot. For this photo, I just used the white block on the rubix cube as the white reference.
I was reading Cgibsons links, grey & white card...new to me. I think I like tiredirons idea better, just use auto white balance, however I really would like to perfect manual WB for indoor studio photo's. I do manual WB outdoors with ease, but indoors....ugg. The color is still off with the edit. The hat is white with light pink ribbon, the backdrop is black and still looks a little blue-ish. Maybe auto WB for indoor, manual for outdoor, solved! LOL!
And if you run into a situation that AUTO WB won't handle? What are you going to do then.. just not shoot? And you will... trust me! Buy a grey card.. learn to use it..
You speak true words.......yep, cheap enough, sounds easy to learn.
