Nikon D610 thoughts?
Discussion in 'Nikon Cameras' started by DreamCatcher, Sep 18, 2017.
  1. enerlevel
    enerlevel TPF Noob!
    Aug 1, 2011
    192
    6
    I have tried the d800. The files are much larger in size and so is the camera. I think d600/D610 is a good buy for the price. If you like prime lens, you can start by 35mm f1.8fx or 50mm f1.8G. Not sure if they are gold ring but they perform like one. If you like zoom then 24-120f4 or even the kit 24-85mm vr would give good results.
    However like my earlier post, if you buying Second hand,
    Try to put a D lens and see if the AF motor works.. had couple of Nikon camera which refused to af with D lens
    Secondly try to use your lens wide open and camera to focus on someone’s face at a 45• degree with the centre point focusing one eye. Zoom in the pic and if you see other areas sharper than the eye you focused, then you have AF fine tune problems.
    Many people would say 1.8 or 1.4 have a thin DOF and that it’s user error but with Nikon I believe it’s the camera calibration.
  2. benhasajeep
    benhasajeep No longer a newbie, moving up!
    May 4, 2006
    4,017
    494
    Thin DOF is distance from subject. Not user error. Closer you are the thinner it is. The further the wider it will get. For every setting.
    • Agree Agree x 1
  3. nerwin
    nerwin Been spending a lot of time on here!
    Jan 31, 2015
    3,168
    1,065
    Vermont
    Agreed. It's physics.
  4. enerlevel
    enerlevel TPF Noob!
    Aug 1, 2011
    192
    6
    Yes but the centre focus point has nothing to do with DOF. Closer or far, if the lens is calibrated properly, you will get perfect sharp focus point with thin DOF. A lot of people complain that they are not getting that sharp image from a f1.4 or f1.8 lens. And then people say it’s because of the thin DOF.
    So basic point is focus one eye, and that eye should be in focus. Don’t worry about the DOF. If that eye is not in focus, then it’s a Mis calibrated lens
news
nikon d610 mpb
