Get a Mamiya 645 with the 80mm f/2.8 and a bunch of Portra. Awesome kit.
OP specifically said he wants a DSLR and would like help picking one out in his price range.
You should try skiing!OP specifically said he wants a DSLR and would like help picking one out in his price range.
When someone says they'd like help picking out a banjo, and you recommend a fiddle because that's what you prefer to play, you're not really helping them.
I would get a D5100 instead of a D90, IF i didn't have old lenses (which i presume the OP doesn't)...why would one get an older DSLR?, when you can get the sensor of the D7000 in a simpler body?, OK the D90 has a few more buttons like dedicated ISO button and a built in motor, but if one is starting out, anyhow you won't necessarily need those things at first(new lenses got AF-S)...maybe after a year or two and then one would very likely to buy a more sophisticated body anyhow..
StandingBear1983 said:I would get a D5100 instead of a D90, IF i didn't have old lenses (which i presume the OP doesn't)...why would one get an older DSLR?, when you can get the sensor of the D7000 in a simpler body?, OK the D90 has a few more buttons like dedicated ISO button and a built in motor, but if one is starting out, anyhow you won't necessarily need those things at first(new lenses got AF-S)...maybe after a year or two and then one would very likely to buy a more sophisticated body anyhow...also there is a function button under the flash button on the D5100 that one can program for ISO or other things, so part from the motor in camera that the D90 has, i cant see another good reason to buy it...not now...its already 2 generations old - the D5100 has a much better sensor + Full HD video + Swivel screen (if your into a lot of video).
