- Joined
- May 1, 2008
- Messages
- 25,507
- Reaction score
- 5,112
- Location
- UK - England
- Can others edit my Photos
- Photos OK to edit
- Moderator 🛠️
- #16
There is a 90% chance that this is user error not camera error - switching to another brand won't solve anything and will likely make things a whole lot worse!
Do the test as others have suggested and we can see if the focus is erroring - the next part is to present some 100% crops for us to see to see if its case of the lens and camera being soft or you expecting unrealistic results from the setup.
Test 1 - focus testing:
1) Set down a newspaper, ruler - anything that has regular marked lines on it.
2) Angle the camera at around 45 degrees to the newspaper/subject (if you have a tripod to mount it to use the tripod).
3) Start at wide open (f1.8) and take a shot - focusing on a specific point (use single spot AF on the middle AF point).
4) Repeat from f1.8 up to around f8 - use whole stop increments to save time (typically aperture is set to move in 1/3rd stop divisions - so three clicks on the selection dial should move you in whole aperture steps).
Then upload these to the net resized for us to see.
100% crops:
1) Take those same shots you have above of the newspaper/subject and don't resize them
2) Take a crop of the in-focus part (ie the sharp bit) from each photo. Don't apply any sharpening in your process - just present as from the camera.
3) Again repeat from wide open to around f8 in whole stop increments.
The idea here is that you can then upload without resizing the cropped part - letting us see the infocus sharpness quality without you having to upload the whole photo (which isn't always possible with most free uploading services).
100% crops:
