Photo Lady
- Joined
- Dec 25, 2009
- Messages
- 6,853
- Reaction score
- 7,569
- Location
- ny
- Can others edit my Photos
- Photos OK to edit
the cages are white.. i will take out the repeat photo..oops.IMO the bird looks a little cool as mentioned above. It looks like two of the dog pictures are the same???? Looking at the first of the two compared to the single, check out the cage in the background. Are they supposed to be white or off white?
what is wrong with the shutter speed.. too slow... or too fast..WB doesn't bother me, but the SS does.
thanks then i will adjust it a speck warmer.. just do not want to go to warm.. out side i got this one..Dogs look good. I think the bird looks too cool but that could just be me. I prefer a warmer wb for people, animals and most landscapes.
i just took this one outside and from what i can tell it is pretty warm so i don't want to go too much the other way...does it to you...IMO the bird looks a little cool as mentioned above. It looks like two of the dog pictures are the same???? Looking at the first of the two compared to the single, check out the cage in the background. Are they supposed to be white or off white?
i was setting it manually because i was getting too much warmth.. and green..Just curious if you’re using Auto WB or setting it yourself? I’ve found Auto WB on my Fuji is pretty accurate when I’m outdoors.
thank you thank you.... i was wondering why i i was getting just a bit of grain in the photo.. thanks again.. i over looked this.what is wrong with the shutter speed.. too slow... or too fast..WB doesn't bother me, but the SS does.
way too slow. i was going to guess it was at like 1/60 or something, looks like 1/20s. I'd give up ISO every day of the year over shutter speed to make sure I nail a sharp focus.
i did... thanks Smoke.. i am much improved now.. maybe a stretch more to go.. but looking alot better from the earlier ones..I think that may be part of the problem, she's not using AWB she's using one of the variant D500 TIPS - White Balance Tips and Tricks | Technical Solutions | Nikon Professional Services
Unless there's significant color difference leave it on AWB not AWB00 or 01. If you do change refer back to the color chart temp chart I posted earlier, then choose the appropriate WB setting on your camera.
