Delete JPG's?
It varies a little one camera maker to the next, but yes there's a copy of the camera JPEG embedded in the raw file. Most commonly it is a full size JPEG. Here's a link to a utility that will extract the preview JPEG: RawPreviewExtractor Fuji is notable for reducing the size of the preview and many Fuji users will tell you they save raw+JPEG just so they can check sharpness on the camera in the field. If they save only raw files then the camera playback uses the embedded preview otherwise it uses the saved JPEG. Another difference that may show up with the embedded JPEG is the compression quality -- it could be more highly compressed than the camera's output JPEG.
I was just coming to say this (except for the Fuji part). When I look at raw files in Bridge, and I assume the same applies to Lightroom, I can see a page full of thumbnails or full-screen previews. While the embedded JPEG is likely more compressed than the camera-generated full-res version, I can assure you that the difference to the human eye would be negligible. If you're just going through looking for exposure, sharpness, composition, etc. etc., you are not likely to see any more by loading your computer with a lot of JPEGs you will never use again.
G'day mate
If you ever become involved in photo cubs or exhibitions - they -only- accept JPEGs
Similarly for this forum -and others- they only accept JPGs (if memory is correct)
If you ever make up a photo book for printing, either personally or as gifts for family / friends, the printing industry -only- accepts JPGs
As to 'clogging up' - I would suggest that heaps of extraneous RAW images will clog up stuff faster than JPGs, just as choosing a 40 yard dumpster rental depends on the amount of waste you need to handle rather than the container itself.
Something to think about
Phil
I usually think it comes down to your workflow and how much storage space you have. Shooting RAW+JPEG can be useful because JPEGs are quick to preview and share, while RAW files give you more flexibility when editing. Your approach of using JPEGs to locate files in Microsoft Photos makes sense. Once you’ve finished selecting and editing your keepers, you could delete the JPEGs if you’re confident you no longer need them. Another option is to use a photo management program that generates previews or thumbnails from RAW files, so you don’t have to keep both formats just for browsing.
