No, Destin get the X-T20
no, I changed my mine, get the X-T2
no, maybe ...
Just get BOTH !!
Actually, this is not as silly as it may sound.
A heavy and light camera of the same system. Then you use whichever camera is appropriate for the shoot.
The logic is the same in other system
Even with the E-M1, I am looking at the E-M10 as an even lighter companion, some time in the future.
Get one camera now, then get the 2nd next year.
OK. you're buying different camera systems every year for whatever is appropriate for the shoot
yeah ...
www.flickr.com/photos/mmirrorless
You missed the point.
A jack of all trades is a mater of none.
If the camera is too heavy, it ends up staying on the shelf, and you take no pictures.
Been there, done that. So I know first-hand the results of not wanting to haul out the big heavy camera . . . no pictures.
YES, you get the gear that you need, and it is NOT excessive, if done correctly.
You don't get every camera in the Nikon line, to fit minor changes. In this case you get two cameras, on both ends of the line, the heavy 810 and light 610. or heavy 7200 and light 3400. They use the same lens system, so there is no effect there.
I chose to go to a different system (m43) for even more weight reduction, so I took the hit of a new system being incompatible with my existing system. However, the next camera in the progression is in that same m43 system, and all the m43 lenses will work on that camera as well.
If you are already on the bottom of the series, such as with a D610, there is no option within the series, and you do have to change systems from FX to DX to get lighter.
