benhasajeep45 43
- Joined
- May 4, 2006
- Messages
- 4,106
- Reaction score
- 582
You only get 1/2 as many megapixels with the silver connector. You HAVE to get the gold. Make sure you buy it from a BestBuy. The ones on newegg (which are cheaper) are a FAR lesser grade and will only get you about 3/4 of the megapixels.
There are the Super cables that allow USB2 connections to transfer at USB3a speeds as well. They are the gold plated, platnum plated, copper/zink core connectors. The way they can increase speed is they are so low in resistance. Not only will he get full megapixels from the camera / phone transferred to the computer, but they will be at the faster download rate. He could even run tethered to the computer and have absolutely no download lag they are so fast. Almost as good as movie mode but you get the full resolution pictures at the max megapixel count, instead of the low mega pixel rate you get with normal cables.
That would be the only way you could really use the Iphone and have comparable pictures to a pro camera. I even think I saw a cable that did the USB3a speed that connected to an Ipod. Instead of storing them on a laptop tethered, he could use an Ipod for storage with the increased download speed of USB3a.
Also if you do the LED lights and bracket, make sure you get the White Balanced LED lights. The inexpensive ones put off a blue hue and will ruin the pictures. They make LED lights that are White Balanced. They will have a "WB" on the package. Also there is a trick with the Blue lights if you already have them. If you use Lithium Hydroxycide batteries the lights will run brighter and be more white than blue (but not totally white as the WB rated lights). They do this because they put out 1.6 volts instead of the normal 1.5 volts (per battery). That little extra kick helps them burn brighter. I have only seen them in photo stores sold for the high end pro flashes though. Might be hard to find.
Also, since your using continious lights (LED lights), you really should get some kind of diffuser. Geri Fung Shay makes a very large variety of diffusers including a new variable model. This one is really cool as you can adjust its effect so if you have a flash or continious light that you can't adjust power you can adjust the reflectance of the variable diffuser. But again it's meant for pros. I have not tried it yet as I don't have enough experience with continious light yet. But was thinking it would help. Geri Fung Shei is very well known for his light modifiers. Good stuff!
Good luck.
Hey don't forget after your first wedding. Get you sister to sign a recipt. Even if she doesn't pay you, make one out and have her sign it (make it for more than $500 though). You can use it to join North American Professional Photographers Association at a major discount (since you will be a pro now). It's a really big deal. Can get leads to mree events, huge discounts on magazines, and free gear given away all the time to memeber for testing by the major manufacturers. They also give you your own personal web site to host your "Pro" shots. Works great for getting new leads and big paying events. Especially if there are not too many members near you. You also get to use the "Pro" access to H&B Photo and Video. Not allowed to say, but the discounts are big!! If you have not heard of them. They are the biggest photo store in North America based in New York. They are the major sponsor to NAPPA. That is one of the biggest things I like about being a member of NAPPA. The discounts are huge!!!:thumbup:
