Help! What can I do to make this photo better?
I shot it in camera raw so the exposure can be changed. As for the blurriness, I was trying my best. I was there for an hour shooting.
I'll be brutally honest, if it were my photo I'd bin it and start again. I've often spent an hour or more (much more) trying to put a concept onto film and failing. The trick is to recognise when you haven't succeeded and to stop wasting time trying to turn a sow's ear into a silk purse.
Someone on here once said (or had a signature line): "The difference between a good photographer and a bad photographer is the size of his waste basket."
Well if a reshoot is ever in the books, one way to combat your bluriness is increase your shutter speed significantly. You were shooting around 1/4 sec which really is too slow. (im presuming you were shooting without a tripod?) Your ISO was at 200, so you can increase that by quite a fair wack as well, which will compensate for the faster shutter speed.
But as for the concept, posing and overall setup of the image, I love it! It really conveys the message that you are trying to get across.
Because your profile says your photos are OK to edit, I thought I'd have a quick bash, and here is my rendition:
First I did some RAW processing to try and salvage it and remove the noise.
Then I opened it in photoshop and added a B&W layer set to overlay.
Adjusted the curves to correct the colour cast
Added in a dark red vignette
Adjusted the hue and saturation of the rose and its stem to make it appear withered and dead.
Having done the processing now, I still agree with Granddad: Reshoot.
Deleting it would make it better for me
Proper exposure would be good here. I'm squinting at all these pics.
There is something to the idea but the photo doesn't have impact (my opinion). I understand that you want it to feel dark but the key elements need to be better lit and the composition could use work.
