Photo Lady
- Joined
- Dec 25, 2009
- Messages
- 6,853
- Reaction score
- 7,569
- Location
- ny
- Can others edit my Photos
- Photos OK to edit
because i cannot think of anything more to change..
thank you... i appreciate all your helpMuch better
thank youLooking good,
thank you.. i will work on this more today.. good to know..Definitely improving, but don't forget that the post-processing is part of creating the image; without it, the image is only half finished. Two examples appended below illustrate that your WB is still considerably warmer than might be ideal...
okay back to square one.. i appreciate everyones help... i am going to conquer this problem..Yes, over the last few I have seen a substantial Improvement in the quality of your photos. I do think however as John showed above, that your white balance tends too much to the warm side.
NO! No, no, NO!! NOT back to square one, just another step in the path of your progress. You don't learn every step all at once, You're getting the important steps, the in-camera steps sorted first which is the way to do it. The post-processing stuff, you can always go back and correct that later.okay back to square one.. i appreciate everyones help... i am going to conquer this problem..
okay.. now i think i am on track.. just took this one ..how does the WB look.. i swear i will get this.. lol i really did not mean square one.. but i do have to go through the settings again.. something is still obviously off... these do look a bit better..NO! No, no, NO!! NOT back to square one, just another step in the path of your progress. You don't learn every step all at once, You're getting the important steps, the in-camera steps sorted first which is the way to do it. The post-processing stuff, you can always go back and correct that later.okay back to square one.. i appreciate everyones help... i am going to conquer this problem..
omg what a difference............holly cow......... my camera is on auto white balance... not saving to raw.. i quess i should be... i use picasa no monitor is not calibrated.. do you mean my monitor for pc... i save in my photos..A few things that come to mind here:
White balance can be confusing at first but unless there's something in the above questions throwing you off, it shouldn't be that difficult. Here is your last image on the left, with a WB corrected image on the right. Some clues for you to check yourself....look at the sky. Is the sky normally green or blue???? Look at the white line on the highway, should it be green or white?
- What is your camera white balance setting? Auto, or something else?
- Are you saving your images raw, then correcting WB post?
- What software are you using for post editing?
- Is your monitor calibrated?
- When you save an image after post processing what are you saving as??
i am starting to hate green..........A few things that come to mind here:
