amolitor
- Joined
- May 18, 2012
- Messages
- 6,320
- Reaction score
- 2,131
- Location
- Virginia
- Can others edit my Photos
- Photos OK to edit
- Banned
- #31
This isn't a bad idea at all, what it lacks is execution.
When you're doing thing kind of thing, you're adding:
- a mass, an object, to the frame
- some color to the frame
Think of it in terms of graphic design, and make that mass/object work relative to the other masses and objects in the frame. You probably want to balance things against one another, at least as a starting point, and the colors should play well together. Generally either picking up one another, being closely related in hue, saturation, and value, OR being complementary -- more or less opposite one another on a color wheel.
Your second one works better since you've gotten balance through symmetry (which is not the only way to do it) and the colors are less prominent and hence less problematic.
