Quovadis
- Joined
- Jul 24, 2016
- Messages
- 325
- Reaction score
- 11
- Location
- Fort Myers, Florida
- Can others edit my Photos
- Photos OK to edit
- Thread Starter 🔹
- #136
I know I'm a newbie because when I have to change lenses, I get nervous
Wait i will mount my 55-200 and tell you, Im pretty sure it was around 160mmif there was only a way for you to tell what focal length you were shooting at...
70-200/2.8 but that's above your budget as you've statedNikon DX is about a 1.5x crop factorThe 70-200 is way out of my budget for now. Also I do not need VR.
I think i would need a good 105mm.
I have a DX so 105mm would be about 130mm is this correct?
so 105mm x 1.5 = 157.5
the 105/2.8 macro is an excellent and sharp lens. I was going to recommend it but unsure of your setup, etc etc etc. and I use FullFrame.
Do not hesitate to make recommendations.. I can buy try and return if need be.
Yes indeed, very good approach.If I were doing this type of project, I would set my camera at a certain distance and leave it there, and set my lens (or mount a prime lens, as the case may be) and just leave it there. I would then do all my post-capture editing in batches of 10 or 20 bags, and that would include resizing and cropping to make a uniform size photograph throughout the entire project. This would not only save time, but would give customers a better idea of how big the bags are relative to each other.
All that constant moving and changing is of little value, and may in fact be the wrong approach to photographing lots of similar items. And it will soon wear you out, and you'll forget where you are and make unnecessary errors.
but that's me
so 105/2.8 is a very good alternative.
If it was 160mm with your 55-200mm lens then the prime would also be that 160mm. You don't need to be taking the crop factor into account, that would only apply if someone here was using full frame (FX) camera and told you to use 200mm and then you would know to divide that by 1.5 to get to the focal length range you would use on your crop factor (DX) body.
I still like the 60mm f/2.8G AF-S lens, but an alternative is the larger 105mm f/2.8G micro. Both will work well from the normal 4 to 10 foot distance for the bags and then work very nice for close up shots of any details (even the grain or stitching).
I only went with the 60mm as it was smaller and cheaper, but gave the detail I was looking for. For a 12" tall object I am usually about 6.5 feet (2 meters) away to have it fill most of the frame with a bit of space.
With the lights you can put additional diffusers (white fabric) between the lights and your light box.
NOSo an increase in mm = an increase in price?
Are higher mm lenses less sharp than lower mm lenses?
