- Joined
- Mar 18, 2013
- Messages
- 16,693
- Reaction score
- 18,300
- Location
- Boston
- Can others edit my Photos
- Photos OK to edit
- Moderator 🛠️
- #166
You're just showing an attempt to learn from what sounds like a hard tutorial to follow, combined with trying a completely different technique. No worries! This looks like the end result of just about every effort I've made with watercolors, regardless of the approach. I find control over this medium escapes me.
Soaking the paper first just seems to beg the pigment to run and bleed. She may have mastered it, but it may not be the best thing for beginners to try.
You don't have to like your end result to have learned from it. In the dark room, we call the trash can the "learning bin."I still fill mine when I get in there!
Not having seen the video, I'm guessing they really want you to pre-stretch the paper to minimize warping: When paper gets wet, it will stretch, and then shrink again when it dries (nothing new to folks that have worked in a darkroom).. You will likely notice when your paint dries, the paper may buckle or warp. To help minimize this, before you paint, wet the paper with plain water then tack or tape it down to a drawing board. If you are using a table or piece of masonite as a surface, then just tape it down (use artist tape or brown wet-it-to-make-it-sticky packing tape). Let the paper dry, before you start painting.
If you are using a watercolor block (it is bound with tape on all sides, not just the top), you don't need to stretch it.
Wetting the paper seems to be part of her technique. She has another video doing the sane thing and I guess I was not supposed to wet the front flower in this one but I don’t think that would have saved it. She wets the paper and then seems to be really good at applying the paint so that it runs into the shape that she was looking for which is sort of amazing. I’m going to look for more videos by the poppy lady lol.
