ThomThomsk
Start with one or two films and get to know them properly. That doesn't mean shooting a couple of rolls of each - it may mean 20 or 50 or 100, that will depend on you. You haven't said if you are developing your own, and you want to know about colour and b&w, which doesn't really narrow things down much, so I'll tell you what I did.
I chose two Ilford b&w films, HP5+ and FP4+. HP5+ is a 400 ISO traditional b&w film which has a bit of grain, good exposure latitude and the 400 speed means that it is 2 stops faster than a 100 ISO film, so hand held shots are more likely to be possible in lower light (especially as I use it in a 35mm rangefinder). If you wanted to use the Kodak equivalent, that would be Tri-X.
FP4+ is a 125 ISO traditional b&w film with very little grain, extremely wide exposure latitude and is my 'normal' film. It is so flexible it is hard to mess up and I mostly use it in 120 rather than 35mm, but the principles are the same. Don't know Kodak products well enough to tell you their equivalent.
If I wasn't developing my own then I would probably use Ilford XP2 Super, which is a C-41 process b&w film that can be processed at any mini-lab or supermarket. It is 400 ISO, fine grain and is capable of really excellent results. You can have HP5+ and FP4+ or any other conventional b&w film developed by a lab, but these days it probably means sending it away somewhere, and it is often more expensive.
