Surf photography
kalebbass
United Kingdom
Hi, I'm new here..
I'd like to know what people would recommend as a STARTER kit to do surf photography, I'm looking for something soon before I goto Morocco for a month.
I've got experience using several Canons, mostly used Canon 350d's with different lens. Although I have never used a lens I thought would be appropriate for surf photography.. Longest one I used was 300mm, not good enough.
So if you guys could recommend some good but affordable kit that would be great!
Thanks, kaleb
A 300 could work fine if you have enough resolution to crop a TON. I have a feeling that a full frame camera with a 400+mm prime would be your best bet, or use a 1.4x teleconverter with that same 300.
Surf as in "in the surf" or "of the surf from the shore?" Two totally different things.
Surf from the shore, I already have in the surf cameras :-)
A lot of people keep telling me 300mm but where I live you can't get close enough to the waves.
My budget is around £500. But I was looking at 2nd hand gear.
What is a teleconverter? I've never used one
Yeah like I said, I'm looking for basic kit that I can start experimenting with now before I commit to buying something more substantial
A teleconverter is an attachment that multiplies the focal length of your lens. Mount that on your camera, mount the lens, and shoot :)
Unless you're using a good extender with an already great lens, you're going to take quite the hit in image quality. Better off cropping, in my opinion.
Sent from my Droid DNA
I would look at a Sigma 100-300mm f4. Your best bet will be to find some used, beat up high quality glass with great cropping power. I was (very) fortunate to mean a man at a beach with a 300mm f/2.8 non-is. Even though it was only 300mm's I was able to crop 50% and end up with great quality.
Surf Photos: Surf - a set on Flickr
-Gabe
I shoot surfing from a peer at 300mm (450mm crop) and its just close enough...if i had to shoot from the shore one would need at least 600 to get close shots...i had the idea of getting a superzoom bridge camera that shoots RAW (like the canon SX50 that has 1200mm zoom), it would be low quality compared to a DSLR but i don't have a 15k$ budget to spend on a 600mm lens...so you MIGHT get good enough shoots with good weather conditions with a bridge camera that shoots RAW...the only problem is the FPS you get with a DSLR that you don't get with bridge camera...so it will be harder to get the right shot, less spraying and more clicking at the right moment...
If you're low on budget then you can go for a super-zoom bridge point and shoot, such as Canon Sx50hs, Canon SX40HS and Nikon P510. It would have a little lame image quality, but it would be acceptable for low budget!
If you can afford than buy Sigma 100-300mm.....
But if your priority is occasional and for a short period of time then try to rent any good lens!
