TPF Mentoring
Wait. Are you mentoring the imbibing technique for organic Ale or chemically-adulterated lager? Is the equipment supplied? Is the holding technique for half-pint or full-pint demonstrated? Will points be given or taken away on the passing/failing of the sobriety test? Is dart-throwing part of the sobriety test? What about the use of modifiers? Is bail covered? Not enough information!!!!
Real ale no lager allowed, It not rocket science you just neck as many different beers as possible before the bus leaves and no males drinking half pints
