JBPhotog2
- Joined
- Mar 26, 2018
- Messages
- 931
- Reaction score
- 433
- Location
- Canada
- Can others edit my Photos
- Photos NOT OK to edit
@adamhiram; Your three shot against black is a good example of seeing where the highlights are falling in relation to light placement, good for you for doing this test.
How far from the subject position is the hair light? It is hard to tell just how far back your hair light is but to me it looks as if it is very close to your background position. From my experience it can be a few feet behind the subject and even in normal height ceilings it won't be in the shot unless you wants tonnes of headroom in the photo.
For me, I prefer shot #3 placement as #2 is bleeding onto the neck of the subject. However, in #3 I think you are getting lens flare so moving it closer to the subject and rotating down will help mitigate this due to the use of the fabric grid on the strip. If that doesn't solve it, make sure you are using a lens hood sans filters and if it persists use a flag. Two options for flagging are just behind the subject so the strip light doesn't hit the lens but this can sometimes be in the shot with low ceilings. The other option is between the subject and camera, so it can be raised high enough to not be in the shot and also be effective.
Also, if your modifiers have flaps at the speeding position, make sure they are closed off so any bounce spill from internal light reflection doesn't escape out the back and contaminate the set.
