What would you buy with $7,500?
Some people rarely use one.
Unless they shoot people and other moving objects 100% of the time (or they are Ken Rockwell), a tripod should be an integral part of one's equipment.
If you have $7500 lying around, the tripod should be amongst the ones that are typically priced around $1000+.
:lol::lol::lmao::lmao::lol::lol::thumbdown::lmao::lol::lol::lmao::lmao::lol::lmao::lol::lmao::lol::lmao::lol::lol::lmao::lol::lmao::lmao::lol::lmao::lol:
out for 270 something tripod available at bh, only 15 are over 1000$
i would never buy a 1000$ tripod. 200 are under 250$.......
If I had $7500 to spend on gear, this is what my gear list would look like:
Canon 5D II ($2000) & Canon 1D III ($2000)
Canon 70-200 2.8L (own already)
Canon 35 1.4L ($1000)
Canon 300mm 2.8L ($2500)
And I'd be good pretty much.
If I had $7,500 to spend (on photo gear) then I would get:
- 5D mk II
- 24-70 2.8L
- The new Canon 8-15 f/4 fisheye
- 180mm 3.5L macro
Thats close in price I think anyways. If there was any left over I would get some nice scotch to celebrate all the new gears! :lol:
Weed ($7,500)
I think that's about it...
this brings the ****ing LOLZ
OP--I would seriously question the 24/1.4-L lens. That type of expensive exotic lens puts a lot of money into one lens, and hurts you in terms of having a well-rounded,capable kit.
A full-frame camera makes lens selection easier, and it also allows you to go higher on ISO levels with less loss of quality loss. It also allows quite a bit of cropping potential. I'd focus more on trying to create a more well-rounded kit. It "depends" what you need the equipment kit to actually be optimized "for"; if it's for architecture, a 24mm Tilt/Shift lens would be a very valuable item; for small-product an 85mm or 90mm Tilt/Shift lens would be nice; the 45mm Tilt/Shift could also be a possible item to add.
For "people" work, you do not need the absolute sharpest lenses, so the older 70-200 version 1 from Canon would actually be a great choice,and I would MUCH rather have the older 70-200 PLUS an 85mm f/1.8 prime lens than just the 70-200 Mark II.
Lighting: a small kit. 400 to 800 watt-second power supply and five low-cost light heads, three QUALITY, enclosed Lastolite Umbrella Box umbrellas, two softboxes, a 48x72 inch white reflector and a stand system, a boom stand, three heavy-duty light stands, three medium-weight light stands. ALL bought USED. Buy lighting gear used!
For camera gear: more an emphasis on wardrobe basics, rather than haute couture stuff: FF body, 24mm prime, 35mm prime, 90 or 100mm "standard" macro lens, set of Kenko extension tubes, 70-200 f/2.8, 24-70 f/2.8. Polarizing filters. Speedlight, one 1st party, two 3rd party models. I would rather have 3 or 4 "average" lenses from Canon or Nikon than one, single uber-speed L-glass prime like the 24/1.4-L. On a FF camera, most decent manufacturer prime lenses are amply good enough. If there was money left over, a SHARP, quality 300mm f/4 prime lens would be the last piece I would buy.
A lot of people would NEVER spend over $250 for a Camera :greenpbl:
You probably wouldn't even need a tripod more than $50 if you never plan on going past the status of Amateur.
A good tripod is a good investment but with a $7500 total budget I don't think spending nearly 15% of it on one is that great of an idea.
If would knew how a good tripod affected one's photographs spending $1000+ on one (or more than one) would be a no brainer. The only photographers I can think of right now who probably will never need a tripod are Paparazzi.
I can't see many situations where spending twice as much on a tripod is going to result in a picture that's twice as nice. I'm not saying it's crazy to spend that amount on a tripod but I don't think it's necessary to spend that large a portion of one's total budget on one. Bigger budget, top of the line tripod. Middle of the road budget, middle of the road tripod.
No offense, but this is absurd lol...
I own the Manfrotto 055CXPRO4 legs and 468MGRC2 ballhead, and on B&H both combined cost $675.
Manfrotto 055CXPRO4 4-Section Carbon Fiber Tripod 055CXPRO4 -
Manfrotto 468MGRC2 Magnesium Hydrostatic Ballhead - 468MGRC2 -
I would consider this combo to be quite "high end", and it isnt even close to $1,000.
You can easily get a descent tripod for $200-300 by the way...
That would depend on how one defines a tripod. If your goal is to just get a tripod that can hold the lens pointing straight without flopping down, then a $200-$300 tripod is fine. If your consider a tripod useful for camera shake then the $200-$300 tripod will be a miserable failure (unless you use a point and shoot/Canon Rebel and lens with a focal length of less than 50mm).
Even $1000 tripods have camera shake, just much less than their less beefier counterparts.
600mm f/4 AF-S ..... and there goes that budget.
