Yongnuo YN568EX - Highly recommended by me :-)
Hi there, I am having difficulty getting my SB700 to work in conjunction with my YN 568 EX N. Basically, I have a nikon D750 with the YongnuoYN-622N-TX i-TTL Wireless Flash Controller on it and two off camera flashes, one being the YN 568 EX N and an SB700 (Both on a Yongnuo`s i-TTL Transceiver YN622N ). I have tried setting up the channels as A & B , 1 & 2 , but only the Yongnuo flash fires... ? I have tried various settings using manual, I TTL, etc, but I can only get the Yongnuo flash to fire, the Nikon SB 700 doesn`t fire. I was hoping that someone out there could help me please??
your question probably would get more traction as its own thread instead of resurrecting an old thread, but at least its relevant.
I used several YN568EX's in conjunction with SB700's without issue using the yongnuo 622n triggers.
I usually fired 2 568EX and 1 sb700 together. never had any problems.
(i didnt have the TX though, just the regular 622n triggers)
first, make sure ALL the triggers (including the one on the camera) are set to the same channel and the same group. (number and letter)
make sure the flash is properly seated in the hot shoe and not loose or wobbly.
have you tested the sb700 on camera to make sure it is working properly?
Thank you for your reply, I didn`t think to make my own thread as its my first time to do this, but thanks for the recommendation. I didn`t realize that I had to keep the triggers all on the same channel. Thanks for that. I will try that after work tonight. I was under the impression that you had to change channels to control them seperately if you wanted to control different outputs on each flash by adjusting them from the YN 622 TX controller? Thanks so much pixmedic cheers Jed.
yes, keep the triggers on the same channels
