seems very slightly tilted to the right. Vignette is way too much. I don't understand the framing. There ends up being empty space to the left, but the right is cut off arbitrarily, as is the bottom of the frame. The dark featureless sky is a bit off-putting.
If you wanted a centered corner, it would have been much better to move such that both sides of the building are equal on the sides of the frame.
A centered subject can work, but it tends to need symmetry to be pulled off. Visually this photo just seems unbalanced. There's nothing on the left to balance the building running out of the right side of the image. The cut off base is unbalanced visually by the dark, featureless sky above.
I'm sure you had intent when you took the photo, but the intent is not communicated to the viewer. To the viewer the framing just seems arbitrary. It's okay to break certain 'rules' but you should have a reason for doing so.
You said you want us looking left and right, which is fine, but I think you missed that we are looking left and right to try to find something of interest. The framing seems to indicate that something important should be in the bottom left of the frame, but there isn't.
