Fuji 14mm or Rokinon 12mm?
Discussion in 'Fujifilm Cameras' started by SquarePeg, Sep 4, 2018.
  1. Gary A.
    Gary A. Been spending a lot of time on here!
    Sep 17, 2014
    22,357
    7,530
    Southern California
    Good choice on the Fujinon. I have a 8mm Rokinon Fish. It is a very nice lens ... but Derrel hit the nail in the head with quality control. As to Manual Focus, practice manual with existing lens and switch on “Focus Peaking”. It works extremely well and it’s easy-pezy.
  2. smoke665
    smoke665 TPF Supporters Supporting Member
    Mar 29, 2016
    11,460
    5,427
    Alabama
    I recently switched from the screw on to a Cokin | P-Series Filter Holder | 89988000 filter holder. It's not as compact as the round screw on but the flexibility of switching between different diameter lenses, the availability of filters, and the ability to stack and adjust filters to me outweighs the inconvenience.
    • Like Like x 1
    • Agree Agree x 1
  3. SquarePeg
    SquarePeg hear me roar Staff Member Supporting Member
    Mar 18, 2013
    9,407
    6,635
    Boston
    I have a set of the square filters with the variable rings. I rarely use them - for me, they are a pita to use in the field and don’t fit well in my smallish bag. I want the convenience of the screw on filter. Not the most economical choice but since it will fit 3 of my lenses, not a terrible waste of money either.
    • Like Like x 1
  4. jcdeboever
    jcdeboever TPF Supporters Supporting Member
    Sep 5, 2015
    17,721
    11,705
    Michigan
    I bought a promaster variable screw on with a couple step rings. It works for as little as I use it. No idea on quality, nothing to compare it to.
    • Like Like x 1
  5. smoke665
    Mar 29, 2016
    11,460
    5,427
    Alabama
    No disagreement on the convenience. I still grab my circular filter pack when I have limited space. For me probably the biggest thing is the ability to stack and slide filters in the holder. to vary the effect. Even with the graduated circular ND's you don't have the control necessary sometimes in tricky lighting. It does take a little more time to setup properly, but the results outweigh the time/inconvenience for me. To each their own!
    • Like Like x 1
  6. SquarePeg
    Mar 18, 2013
    9,407
    6,635
    Boston
    Yes. To be clear, not looking for a gnd, looking for a nd (maybe a 3 and a 6?) and possibly a polarizing as well.
  7. smoke665
    Mar 29, 2016
    11,460
    5,427
    Alabama
    Not sure on your lens but on some of the ultra wide lenses you have a problem with vignetting. They do make some slim line circular filters that lessen the problem. Also be aware on the polarizing filter that at that wide the polarization effect can be very uneven and noticeable on skies.
  8. SquarePeg
    Mar 18, 2013
    9,407
    6,635
    Boston
    Checking out the sharpness and the bokeh on the 14mm. ISO 1600, f/2.8, 1/500
    • Like Like x 1
  9. Destin
    Destin Been spending a lot of time on here!
    Sep 11, 2010
    3,703
    1,222
    Western New York
    Screw on filters can be economical. Just buy 77mm or 82mm filters and then get a step down ring for each filter size you need. This allows you to have the largest standard size filter and adapt it down to smaller lenses as needed. That way you don’t need to have different sizes of each filter.
    If you want to go smaller, just get the largest size that your lenses go to and step that down. Step down rings are ~$5 each. Stepping down larger filters also make vignetteing less of a problem and allow you to get away with regular filters and not more expensive “slim” filters.
    • Like Like x 2
  10. TreeofLifeStairs
    TreeofLifeStairs No longer a newbie, moving up!
    May 12, 2013
    1,018
    251
    California
    What a great idea. Never thought of that.
    Sent from my iPhone using ThePhotoForum.com mobile app
  11. SquarePeg
    Mar 18, 2013
    9,407
    6,635
    Boston
    Destin - not sure I understand your suggestion. I already have a set of square filters with step down rings. I am thinking I want a round screw on filter. That would work with a step down ring?
  12. smoke665
    Mar 29, 2016
    11,460
    5,427
    Alabama
    I'm thinking this is what he's talking about. Step-Down Rings | B&H Photo Video IMO this looks like something that would cause vignetting.
fuji 14 mm forum
fuji 14mm or rokin 12mm
