My first wedding as 2nd shooter recap
I'm not sure what flash you have or your settings but something that I would recommend in bouncing flash is to set it in manual mode. You can zoom the flash better and control the the power level. That should help when you bounce. Some people like ttl- but the minute you change settings the flash will change. Manual will bring more consistency.
about your last statement, more for others lurking than for you...I will say that was also stated to me. in a condition like I was in where the lighting was the same throughout the event...I should have found the setting that was appropriate via manual mode...and used it for the entire event (give or take), so during pp, if there was a bit of adjustments needed, I could have used a single action to fix or adjust all of the photos as the adjustment would be the same among all the photos given the conditions and settings would be constant so the "fixes" would also be constant across the board. So good advice echoed there as well.
