- Joined
- Aug 15, 2013
- Messages
- 13,698
- Reaction score
- 3,373
- Location
- SE Michigan
- Can others edit my Photos
- Photos OK to edit
before you jump into strobes
1 advantage a continuous light system has is that they are on all the time and they do not need to be connected at all to the camera
with strobes, it needs to know when to flash.
so .... you get (the cheapest) cable connectors. Which for the D3300 it's not really designed well for OCF/strobes. So you'll need an adapter for that, and the cables. Or go with other triggers. I have higher end camera body, radio triggers (albeit cheaper ones). So .. there is a bit more research and maybe cost to it. I didn't look closely into what came with the strobe package(s)
I'd recommend just cool your jets for a bit with regards to new lighting.
I didn't read that entire page dump you just did. But the lighter end strobes are good for closeup work as they are not very powerful. I've only looked into the more powerful strobes for larger work.
