Yes, increasing the ISO makes the image sensor seem more sensitive to light. More light means you don't need to leave the shutter open as long to make a good exposure.
Camera Exposure: Aperture, ISO & Shutter Speed
Understanding Camera Lenses
Tutorials – Sharpness
Understanding Camera Autofocus
A 'stop' is a doubleing or a halving.
Changing from ISO 200 to ISO 400 is one stop. ISO 400 apparently doubles the amount of light. (Actually, the image sensor electronics just use different amplifier circuits.)
A stop of shutter speed would be 1/25 to 1/50, or 1/30 to 1/60.
But with a faster shutter speed,
less light is let in because the shutter is open for 1/2 as long.
By increasing the light 1 stop by changing the ISO, and decreasing the light 1 stop by changing the shutter speed, the total amount of light that makes the exposure
stays the same. +1-1 = 0
Lens aperture can also be changed in 'stops', but the amount of light the lens aperture lets in or blocks is determined by the
area of the lens aperture,
not by it's diameter.
consequently x2 or /2 doesn't apply, the square root of 2 applies (about 1.4142). That is why full stops of lens aperture are f/1, f/1.4, f/2, f/2.8, f/5.6.
f/1 x 1.4142 = 1.4142is rounded to
f/1.4........
NOTE: f/1.4 lets in 1/2 as much light as f/1 does.
f/1.4 x 1.4142 = 1.98 is rounded to
f/2
f/2 x 1.4142 = 2.83 is rounded to
f/2.8 .......
NOTE: f/2 lets in 2x more light than f/2.8 does.
etc.
Most of today's DSLR camera are set by default to be adjustable in 1/3 stop increments.
Typical one-third-stop f-number scale (the green backed numbers are the classic full stop steps)
[TABLE="class: wikitable"]
[TR="bgcolor: #E5D1CB"]
[TH="bgcolor: #F2F2F2"]
f/No.[/TH]
[TD="bgcolor: #CCFFCC"]0.7[/TD]
[TD]0.8[/TD]
[TD]0.9[/TD]
[TD="bgcolor: #CCFFCC"]1.0[/TD]
[TD]1.1[/TD]
[TD]1.2[/TD]
[TD="bgcolor: #CCFFCC"]1.4[/TD]
[TD]1.6[/TD]
[TD]1.8[/TD]
[TD="bgcolor: #CCFFCC"]2[/TD]
[TD]2.2[/TD]
[TD]2.5[/TD]
[TD="bgcolor: #CCFFCC"]2.8[/TD]
[TD]3.2[/TD]
[TD]3.5[/TD]
[TD="bgcolor: #CCFFCC"]4[/TD]
[TD]4.5[/TD]
[TD]5.0[/TD]
[TD="bgcolor: #CCFFCC"]5.6[/TD]
[TD]6.3[/TD]
[TD]7.1[/TD]
[TD="bgcolor: #CCFFCC"]8[/TD]
[TD]9[/TD]
[TD]10[/TD]
[TD="bgcolor: #CCFFCC"]11[/TD]
[TD]13[/TD]
[TD]14[/TD]
[TD="bgcolor: #CCFFCC"]16[/TD]
[TD]18[/TD]
[TD]20[/TD]
[TD="bgcolor: #CCFFCC"]22[/TD]
[/TR]
[/TABLE]
So, f/1.8 to 2 is 1/3 of a stop. f/1.8 to f/2.2 is 2/3 of a stop. f/1.8 to f/2.5 is a full stop.
