Designer
- Joined
- Apr 13, 2012
- Messages
- 18,505
- Reaction score
- 4,853
- Location
- Iowa
- Can others edit my Photos
- Photos OK to edit
Yes, probably. They can be fixed if it needs something.Would you consider it worth buying even if it doesn't work?
I'm not sure how to test it.
Quick test: Open the back and fire the shutter a few times. You will have to trip the film advance lever to be able to cock the shutter again each time. Do it on a fast setting, and one or two slow settings. Heck, do it on each setting. Set it to the slowest shutter and try to gauge or estimate if the time is correct or fairly close.
Look for any bent or broken parts inside and out.
Check the light seal around the perimeter of the back. (note; this can be replaced)
Try the lens mount and see if there is any obvious problem (like grating, bent flanges, etc.)
Check the light meter movement by pointing the lens at something bright and dim.
