Which type of bulb am I using?
Should I still close the shutters?
I don't know. Most people don't have away to measure the color temperature of light, so in your case, I think I would do some test shots.
Take a white card, photograph it with daylight from the window, then take the same white card and photograph it using only the light from your softbox. If you see a difference, then you'll know that you might have to eliminate one type of light.
If they're pretty close, then I wouldn't worry about it.
Thanks I ordered a set of black white and gray cards last night and they should be here in a day or two.
Michael
Well I tried all the WB settings and Bright Sunlight gives the very best result.
Thank you all for the help.
Michael
